MultiUser Project
AGorbatykh
MultiUser Project
Post by AGorbatykh »
How can I work with my colleagues in a single project?
We've got SVN and there's no problem to work with text-files (*.pnl, *.ctl, etc), but there's no way to merge binary-files (for example db-folder). How can we delete any dp or dpt? (How to create we understand) And how can we merge plantModel or changes on any administration settings?
With best regards.
Re: MultiUser Project
set up a single running central server which is running the Event and Data Manager, to which all workers connect their UIs.
Then you have a single DB, which you can then at times export into ASCII Files to check in into SVN
AGorbatykh
Okey. I've create standart project on a server then create "Remote UI" project on my PC. It's work. Any of us can change some dp or upgrade plantModel... But separatly. I mean only one of us can work with repository at the same time. When somebody else try to turn on gedi on theirs own PC it will get error message: "License error: Maximum number (1) of allowed instance of manager rapa reached". We've got more then 6 dongles for work, using WinCC OA 3.14.
Were previous steps are done right or I've configure something wrong? How can I configure project to join other dongle license?
I don't know what licenses you have. For the multi-user project with 6 people connecting to the one central server, the server needs a license which allows 6 simultaneous UIs for parametrization.
Please get in contact with your sales contact to clarify this issue.
