Gesture Trigger Example Please
Flick
Post by Flick »
I’m putting together a template for a new project, I want to be display/hide panels from the top, bottom, left and right of the base panel using the gesture trigger event. I’ve had a look in the 3.14 patch 3 demo project and can’t spot any examples. Could you either point me in the right direction in the demo project or give me an example?
Re: Gesture Trigger Example Please
The embedded module and panel have the 'GestureTriggered' event, which can be used to display/hide panels.
The contents of the parameters are described in the online help under: Graphics editor (GEDI) -> The Property Sheet -> Properties and events of the panel
adriantaw
Post by adriantaw »
I have also a difficulty when trying to create a multitouch gesture for a button. The information on the WinCC OA help does not help much.
Can you point out to an example or give us more clear direction?
the "GestureTriggered" event is a panel event and cannot be defined for graphical objects.
Maybe this is the information you were missing.
Which multi touch gesture do you want to define for a button?
