setValue object path structure ?
Kris Daniels
Post by Kris Daniels »
Hi Guys,
Could someone explain me how I access an object that's inside a embedded panel from an other embedded panel.
I know we can access this with the function setValue but how is the path structure ?
For example.
I have a panel (main.pnl) with 3 embedded modules (Header,Main,Footer) in the Footer module we load a Footer.pnl with 2 embedded modules (Footer_Top & Footer_Bot)
each module has also a panel (Footer_Top.pnl and Footer_Top.pnl). I want to access an object from the Footer_Top.pnl to Footer_Bot with the setValue function.
Main.pnl (panel)
---- Header (embedded module)
---- Main (embedded module)
---- Footer (embedded module)
-------- Footer.pnl (panel)
------------ Footer_Top (embedded module)
---------------- Footer_Top.pnl (panel)
-------------------- Btn_1 (object)
------------ Footer_Bot (embedded module)
---------------- Footer_Bot.pnl (panel)
-------------------- Object_1 (object)
for example :
setValue(Main_Footer_UINumber_Footer_Footer_Top:Object_1,"visible","true") ?
Kind regards,
Kris
Re: setValue object path structure ?
how to access shapes in other modules/panels is described in the WinCC OA help.
You will find the chapter "Access shapes in other panels and modules" when searching for the keyword "setValue".
The syntax for the path is "moduleName.panelName:shapeName".
The panelName is not the file name, it is the name given when opening the panel.
Kris Daniels
Thx Leopold,
That's what I was looking for.
Kind regards,
Kris
