Can I embed a DPE online value in a DPE's alert handler came and went text.
Example
"Fault code " & & "Active"
Embedded DPE values in alert handle came and went text
- BuckB
- fmulder
Re: Embedded DPE values in alert handle came and went text
James,
I believe the anwer is yes and no.
No: I don't believe that you could change the came and went text 'live'. You'd have to de-activate the alarm before being able to change it. The value is of course one of the attributes of the alarm but you'd be unable to 'embed' this value directly in the alarm text
Yes : You would be able to display a column that has the exact text that you want. The WinCC OA API (C++) has a method to implement a DLl that adds additional columns to the AES table. You could implement a C++ function that formats a string (with or without a color) exactly to your wishes.
I've done the same. I've implemented such a DLL that combines two fields. Direction (came/went) and acked were combined to show 'came - unack' or 'came - ack' etc..
You'll find an example in : C:\\Siemens\\Automation\\WinCC_OA\\3.14\\api\\SampleTabUtil
Another can be to:
- make use of the alert comment and display that (not the very best idea)
- make use of the 32 possible additional columns (a little bit less worse)
Good luck
share the fun
Frenk Mulder
Another can be to:
Good luck
share the fun
Frenk Mulder
- BuckB
Thank you Frank. I'll check into it. Sounds like more fun than I should be allowed to have.
how to add a user defined column to the AEScreen is described in the following chapter of the WinCC OA help:
System management --> Diagnostics --> Alert and event panel --> Example of how to add a user-defined column
Why do you want to include the value into the text?
What's the use case for it and where shall this information be displayed?
