Could I add shapes to panel dynamically?
- Piterskiy
I can't find any info about the subject (adding shapes by scripts during runtime)
Re: Could I add shapes to panel dynamically?
adding single objects during runtime is not possible.
With the CTRL-function addSymbol() you can add reference panels during runtime to a panel. The added references are not saved to the panel file, they only are added for the current panel displayed in the UI.
- RudiKreiner
You get almost the same effect with single objects, by setting their visible attribute to FALSE in the GEDI, then to TRUE in a script whenever you want it to appear.
- Piterskiy
Thank you for your bright ideas!
