Hi;
In our project We have to define OPC tags for WinCC OA opc server. But There are a lot of tags and It will be take a lot of time individually defining in DP Groups panels. Is there any solution for example is it possible import from file included necessary tags.
Thank you
Best Regards,
Hakan
Defining OPC tag for OPC server
Re: Defining OPC tag for OPC server
you could use wildcards at the configuration of the DP-group to include the datapoint-elements which has to be available at the OPC-server. Another possibility would be the configuration of the DP-group with a dpSet() from a script where you read the list of OPC-tags from an external source/an file.
If you need further assistance please send an support request to the following email-address:
support.automation@siemens.com
- hakan
Hi;
I cant understant how can I use dpSet() function to add to OPC Read DP group for defining OPC Server tags. Can you give me a example shortly.
Best Regards,
hakan
Best Regards,
hakan
to define the dp-group-settings you have to set two elements of the _DpGroup-datapoint which is defined as the dp-group used by the OPC-server.
_DpGroup_Public.Types - a dp-type-filter can be defined (if necessary), if no filter is necessary an empty string has to be defined
_DpGroup_Public.Dps - dp-filter or a list of datapoint-elements can be defined
Please notice that both arrays need to have the same number of items for the correct functionality.
