Hi forum
Is it possible to create the datapoint structure from a .cid file in the IEC61850/61400 engineering tool?
Or is it manual work? :blink:
Christoffer
IEC61850/61400 Engineering
Re: IEC61850/61400 Engineering
as described in the help for WinCC OA 3.14 reading of CID files to configure IEC devices is supported.
- ChristofferG
Hi Leopold
I have been looking in the WinCC OA help and have figured out how to configure a IEC61850/61400 device, but i would like to "import" the data structure from the CID file to the Para.
Getting all datapoint types and datapoints created corresponding to the structure in the CID file.
I have a really exhaustive CID file describing the data structure of a system using IEC61400-25 and I would like to find a way of importing this into the Para besides doing it manual :dry:
Christoffer
Christoffer
there is no predefined solution available to import the data structure defined in the CID file and to create corresponding dp-types and datapoints includiing their configs (e.g. _address). You have to define this function on your own.
As every project uses its own data structure there is no possibility to define a mapping which would fit all customers requirements.
