Using addSymbol inside a tab\'s registerpanel
10 posts • Page 1 of 1
peka
Post by peka »
Hi all,
anybody knows if addSymbol can be used to add a reference inside a tab's registerpanel? If it is, what's the syntax?
Using addSymbol inside the registerpanel (initialize) adds the reference to the panel instead the tab registercard, where the function was called from. So the reference (in this case a button) is visible, independet which registerpanel is selected.
Br petr
RudiKreiner
Re: Using addSymbol inside a tab\'s registerpanel
Post by RudiKreiner »
To use addSymbol in register panel tabs, you need to pass myPanelName() to the parameter panelName, instead of a just an empty string there. That is described in the WinCC OA help, in the description of the addSymbol() parameters.
peka
Post by peka »
Hello Rudi,
thanks for fast reply.
Yes, now i see it, clever as i was i just checked the common description and hint section...
AliBou
Post by AliBou »
doesn't work for me 3.16 ?
peka
Post by peka »
I haven't tested it yet, but according to help you also have to use myModuleName
"In order to add an object in a tab, the both parameters have to be replaced by the functions myModuleName() and myPanelName(). If an empty string "" is used instead of myPanelName(), so the tab is used as this panel."
AliBou
Post by AliBou »
I already make it in initialise script of tab:
addSymbol(myModuleName(),myPanelName(),"objects/test.pnl","test",makeDynString(),50,50,0,1,1);
It works in the following ways:
1) when you have your script inside the panel inside the tab, use addSymbol(myModuleName(), "", ...); // panel name as empty string
2) when you have your script outside of the tab, use addSymbol(TAB1.panelAt(0), ...); // insert on panel at tab index 0
AliBou
Post by AliBou »
Thanks for your response
It's still not working !!!
i tried both methods inside and outside the Tab
addSymbol(myModuleName(),"","objects/test.pnl","test",makeDynString(""),50,50,0,1,1); inside tab
addSymbol(myModuleName(), TAB1.panelAt(0),"objects/test.pnl","test",makeDynString(""),50,50,0,1,1); outside tab
the object is added but in the panel not in the Tab ??
I tested it with the attached panels. open the addRefToTab.pnl
Tested with 3.16 P2 https://www.winccoa.com/fileadmin/image ... 181026.zip
panels-20181026.zip
(2 KiB) Downloaded 279 times
AliBou
Post by AliBou »
Thank's
