Can anyone tell me how to clear the alarm history in a PVSS 3.10 project.
With kind regards
Frenk Mulder
How to delete the alarm history in a PVSS 3.10 project
- fmulder
- RudiKreiner
Re: How to delete the alarm history in a PVSS 3.10 project
Have a look at the configuration page under System Management, tab Database, Archive Export Raima where you can configure how many days of history you want took keep and how often old stuff should be deleted
- fmulder
Thanks. My question was caused by a project that seems to have corrupted alarms. I know that there was a procedure to simply clear all alarms.
The following link[ url=https://portal.etm.at/index.php?option= ... =2784#2797][/url] show how it can be done in newer versions.
I believe that the procedure for 3.10 is different but can't remember or find how to do it in 3.10
in 3.10 it is the same procedure as described in the other forum entry.
The only difference is the name of the command, instead of WCCOAtoolRepairDb you have to use PVSStoolRepairDb.
- yavaskoray
Is there a way to delete specific alarms from the history?
Koray
Koray
- kilianvp
Like a DPE Filter? Nope
There is no possibility to delete specific alarms in the history.
When using RAIMA alarm archiving You can delete the complete alarm history or specific time ranges (deletion of archive file sets from the RAIMA database).
- yavaskoray
Thank you.
