I need to read the historical data from the WinCC OA 3.13 Histval table from an application developed using Visual Studio,
for this purpouse i have registered WCCOAoledb.WCCAoledb in windows\\system32
the code i am testing is the following:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Data.OleDb;
using System.Data;
using ADODB;
namespace BD_WINCCOA
class Program
static void Main(string[] args)
try {
string strProvider = "Provider = WCCOAoledb.WCCOAoledb;Data Source=localhost:4444";
string strSql = " SELECT DPNAME FROM HISTVAL";
ADODB.Connection con = new ADODB.Connection();
ADODB.Command cmd= new ADODB.Command();
ADODB.Recordset rs = new ADODB.Recordset();
object recs;
cmd.CommandText = strSql;
Console.WriteLine("Before Connecting");
con.Open(strProvider, "", "", -1);
Console.WriteLine("Connected");
rs = con.Execute(strSql,out recs, 0);
Console.WriteLine(rs.RecordCount + " registers!");
con.Close();
catch (Exception ex)
Console.WriteLine("Error: " + ex.Message);
finally
Console.WriteLine("Click to close");
Console.ReadKey();
Thx in advance for your help.
How to connect to WinCC OA HISTVAL table values from Visual Studio
- ubusto
Re: How to connect to WinCC OA HISTVAL table values from Visual Studio
from the description I cannot see what the problem is.
Do you get an error when executing the function?
Have you tried to read data using the SampleHistDB.xls file (source directory at the WinCC OA installation)?
The example for WinCC OA version 3.13 is using the wrong name for the OLE-DB-file.
In the newest version 3.14 it is already corrected.
Instead of
Set oADOConn = New ADODB.Connection
oADOConn.Open "Provider = PVSSoledb.PVSSoledb"
the following code needs to be used
oADOConn.Open "Provider = WCCOAoledb.WCCOAoledb"
Please modify the code on your own when using this example.
Instead of
- ubusto
thx for reply.
I am trying to connect but i get an error saying: The 'WCCOAoledb.WCCOAoledb' is not registered on the local machine.
I am capable of reading data using the SampleHistDB provided and even with the Database browser program i can connect to the database.
But when i try to connect to the database using the same connection in a program developed from me i get the error described above.
It would be very appreciated if you could provide me more information about how a third party program can connect to the database, i mean, if there is a specific .NET framework that should be used or maybe an specific oledb.dll must me registered, or whatever information you think it would be important to know.
thx in advance.
thx for reply.
thx in advance.
- fandersen
Hi Urko,
have you checked your build target setting (x86, x64) in visual studio?
If you are using the setting AnyCPU your application runs in the OS "native" format which is 64bit for an x64-OS and 32bit for an x86-OS. Running an application in x86 or x64 also makes a difference in which registry hive your application is looking for the 'WCCOAoledb.WCCOAoledb' registration.
Where can I get this dll to test it?
Florian
Florian
- ubusto
thx sir,
this worked for me!!!
