GIT for Gedi?
- michel.eijgermans
GIT for Gedi?
Does somebody allready has experience with the useage of GIT for versioncontrol in Gedi just like the SVN library does.
- yavaskoray
Re: GIT for Gedi?
Hello Michel,
We have used it in v3.12 and v3.13. I have not tested in in v3.14, but it should work.
Koray
Koray
- RudiKreiner
Re: GIT for Gedi?
If you are using version management for your panels then you should know about this issue as well: https://portal.etm.at/index.php?option= ... 26&id=3019
- michel.eijgermans
Re: GIT for Gedi?
It seems that i don't have the correct access-rights to view the page. But if it's related to the fact that panelfiles contains numbers of used object references, and that languages should be in the correct order between two seperate projects. Then yes i'm aware of this. Thank you.
If it contains addition information than it would be nice (of ETM) to enhance my userrights to view the page suggested.
Re: GIT for Gedi?
the referenced link is only available for users which are part of the "Inner Circle". The is a special "Inner Circle Program" available for our WinCC OA partners.
- RudiKreiner
Re: GIT for Gedi?
You don't really need access to that issue, you just need to know that there was a QT Lib bug that caused random changes of the panel files when they were in xml format.
So if you are using xml files with WinCC 3.14 then you should install Patch P002 where this problem was fixed.
