Disaster Recovery
Barbara.Kreische
Disaster Recovery
Post by Barbara.Kreische »
Hello Support Team, is it possible to install and use Disaster Recovery without Oracle client? The value archives are not saved in external RDB. They should be excluded from Disaster Recovery. We use WinCCOA Version 3.11 SP1. Thanks & Regards Barbara Kreische
a_labropoulos@akatt.gr
Re: Disaster Recovery
Post by a_labropoulos@akatt.gr »
Hello.
We are using DRS feature to our project. I have notice that when I have insert a Datapoint to sync to both sides (PSS, SSS) ,only the online values are synchronized.
In this Datapoint I also using and alert handling 5 ranges but when I change the range limit to the one side (for example at PSS side) the values does not synchronized with the SSS side.
Is there any solution to synchronize also this attributes (like alert handling limit ranges);
Thanks for your time..
the configuration changes are transferred to the other systems with an ASCII export and import.
This update is made in a defined interval.
Please check the DRS configuration and the update interval for the configuration.
