Get back plastique style for the UI
1 post • Page 1 of 1
agruber
Post by agruber »
Lately some of our customers asked us how they can back their old look and feel when they used some of the QT styles like "plastique" (UI parameter "-style plastique").
Starting with QT 5, used in WinCC OA >= 3.13, these styles cleaned up. Now there is only the platform dependent default style and the style "fusion".
http://blog.qt.io/blog/2012/10/30/clean ... ng-fusion/
However, QT did not remove them completely, they are still available as source code, which can be found here:
https://gitorious.org/qt/qtstyleplugins
In a first test I could compile these with QT5.5 for Windows. I attached the DLLs here. Just extract them to your /bin folder of your WinCC OA 3.14 installation and try for yourself.
Please note, this is not officially supported. Still I hope this helps some of you.
Andreas Gruber https://www.winccoa.com/fileadmin/image ... styles.zip
styles.zip
(155.82 KiB) Downloaded 268 times
