Database error
Bayandin
Database error
Post by Bayandin »
I have a trouble with WinCC OA database. Because of some reason one time para don’t save configs “Alert handling” (_alert_hdl) and “Peripheral address” (_address). I add it, press OK and it store until I restart the project.
In log’s one of the error described here: https://portal.etm.at/index.php?view=it ... &Itemid=54
I collect all logs and attach it here. File textvar.db have 16777214 records. What should I do?
WinCC OA v3.14 P001.
Windows 7 Professional x64. https://www.winccoa.com/fileadmin/image ... s/logs.zip
logs.zip
(232.45 KiB) Downloaded 226 times
fmulder
Re: Database error
Post by fmulder »
Just for testing : export your datapoints. Create a new project and import it all there.
when it then works, then you've probably reached a limit.
Did you create many datapoints ? The datapoint ID is a limited number. You will reach the limit when you delete and create datapoints all the time.
Frenk
Bayandin
Re: Database error
Post by Bayandin »
It works.
I have ~5000 dpe in the project. I can't clear unused datapoint ID's?
Re: Database error
from the zip file I can see that the limit for the configuration history was reached.
For details please have a look at the following FAQ:
