Platform: Windows 7, Windows 2008 R2
Version: WINCCOA 3.11+SP1
I have a directory holding multiple directories which in turn have text files in them.
From a panel I try to load/open a file using fileSelector() function. The fileSelector() goes successfully to the UNC path specified, but does not list any files there. The work around then is to I have to move one directory up and come back again to the desired directory.
int rc;
string filename;
rc=fileSelector(filename, "//ACS-0/DATA/MPS_DATA/DPQPSP",0,"*.txt");
Bhavna
fileSelector() dialog does not list files
- bhavna
Re: fileSelector() dialog does not list files
If anyone has faced similar problem, please let me know the solution to it or maybe some other method to open/load text files.
- dbindernagel
Try this (adding a slash to the end of the path):
rc=fileSelector(filename, "//ACS-0/DATA/MPS_DATA/DPQPSP/", 0, "*.txt");
- bhavna
No, it does not work. Recently I made a small change. Instead of writing "//ACS-0" I wrote "//acs-0" (i.e lower case) and it seems to work.........somehow.
- RudiKreiner
I even have this problem with the GEDI's "Open Panel" file selector in V3.14. If I switch to another project and then back to the original one again then it works.
It is not a big deal if you know that, but if you don't then you get a big scare :ohmy: because you may think that all of your panels have been deleted
- RudiKreiner
I think this is a bug in ETM's File Selector widget.
Do they know about it?
Can they reproduce the behavior?
Will they fix it?
Will they fix it?
The fileSelector() internally uses Qts QFileDialog. If there's a problem then probably a bug in Qt.
And no, we don't know about it.
Checking the Qt bugtracker ...
I find: https://bugreports.qt.io/browse/QTBUG-17750
Please check if that is the problem you encounter and if so, vote for this Qt bug or add a comment.
- RudiKreiner
Thanks for the info. It looks like the problem really is the QT bug that you referenced.
Even though I mount as
\\\\Standard\\projects
with a big S at the beginning on my PC,
the windows explorer shows me that the directory is named
\\\\standard\\projects
with a small s at the beginning.
I voted for the Qt bug, hopefully they will fix it soon.
- RudiKreiner
I'm guessing that the first time I mounted I used \\\\standard\\projects, but now I am using the proper name \\\\Standard\\projects, but somehow windows "remembers" the lower case name in the repository somewhere.
Until the QT folks fix the bug, I guess that I have to be more careful with the case sensitivity of my mount points.
