[3.14] [raspberry pi] colorToRgb() isn\'t working
The function colorToRgb() isn't working with my Raspberry Pi Version.
PC version works fine.
Im not sure if i can report that bug via Siemens Portal.
Re: [3.14] [raspberry pi] colorToRgb() isn\'t working
This function is not platform specific, therefore I see no reason why it shouldn't work on the Pi the same as it does on other platforms.
Are you using the same project, especially the same colorDB files on the results you compare ?
Can you post a simple example where it does not work for you ?
it works if im using a UI. However CTRL isn't working.. Maybe i need a CTRL
You mean a CTRL manager ?
Yes, that's right, it is not available in a CTRL manager, since this has nothing to do with UI and graphics.
The function is only available in a UI manager.
true! sorry!
im using mobileApp_ColorDB_getColorRGB() now .. works great
