Mass parameterization
xavi.aran
Post by xavi.aran »
There is a tool for mass parameterization data which does not export to excel with dplist?
I need to write lots of data and it is not easy or friendly treatment.
For example WinCC v6 o v7 has the Configuration Tool. This is really useful!!!!!!
Re: Mass parameterization
can you please describe your requirements are little bit more accurate.
Which data from the WinCC OA-project do you want to import/export with Excel?
xavi.aran
Post by xavi.aran »
Yes, we are working on a database for a rail project that will have many structures and many points.
We need an easy tool to handle these issues. Modify, create new points, add new data config....
I worked a little with the ascii export-import and I see that is a little hard to process the data.
Is there any way to make this a little easier?
please have a look at the "Mass parameterization" chapter of the online-help.
When using master-datapoints with power-configs you can easily create new datapoints and it-äs configs with Excel using the MassPara-AddIn. The AddIn allows to load/edit/save ASCII-files in format V3 and V4.
xavi.aran
Post by xavi.aran »
yes, of course I looked at the help. The Addin you mention I can not use it because it gives many errors. Even too much data fails to load.
There is no application that is really useful for managing massive data than the export-import ascii or addin?
when you get errors when using the mass-parametrization and/or the Excel AddIn we should investigate the cause for these errors.
Please send a detailled error-description to the official support-address support.automation@siemens.com.
At the topic or at the beginning of the description within your mail please write which PVSS-version/WinCC OA-version you are using.
