Ethernet IP (eip driver) symbolic name syntax
johna_ssa
Post by johna_ssa »
I am using WinCC OA 3.14 with the EIP driver connected to a AB CompactLogix PLC. The driver connects with out error and I can read (set up periphery address for a DP) tags from the "Controller Tags" table.
However, I am not able to successfully read tags from MainProgram tag table. What is the proper way to format the PLC symbolic tag name to reference tags in the AB program tables?
johna_ssa
Re: Ethernet IP (eip driver) symbolic name syntax
Post by johna_ssa »
To close the loop on this, it turns out that you can't access tags in the AB program space using a symbolic reference like "Program:routine_name.tag_name". The only tags you can access are the ones in the global "Controller Tags" table.
