Infos for update with 3.13 P009 - AEScreen
1 post • Page 1 of 1
Dear Customer,
this information only affects projects where user defined columns are used in the AEScreen. It possibly can happen that duplicate position numbers are saved in the internal _AESConfig datapoints.
As a consequence acknowledging alerts in the AEScreen might not work and no error is reported after the installation of P009..
We have already prepared a fix for it which will be delivered within the next summary patch.
Until the patch is available (date is not defined right now) please use the attached script to modify the internal _AESConfig datapoints.
-- copy the file to the scripts folder of your WinCC OA project
-- start a CTRL -manager to execute the script
For every datapoints which was checked you will get a debug message that the check was finished.
When the debug flag "-dbg aes_UDA" is set as start parameter you will get more detailed information.
Please apologize the inconveniences!
WinCC OA / PVSS Support https://www.winccoa.com/fileadmin/image ... Config.ctl
[The extension ctl has been deactivated and can no longer be displayed.]
