Select query from all DPs
najoua
Post by najoua »
I have the following sql query that select all alerts of a DP. What is the syntax to do a select query of all available alerts of all DPs in the Para module?
SELECT ALERT 'COUNT(_alert_hdl.._value)' FROM 'MyDP_example' WHERE '_alert_hdl.._act_state' = 1
Thanks,
michel.eijgermans
Re: Select query from all DPs
Post by michel.eijgermans »
Have you tried the following statement,
SELECT ALERT 'COUNT(_alert_hdl.._value)' FROM '*' WHERE '_alert_hdl.._act_state' = 1
najoua
Post by najoua »
Thank you Michel ! I tried to use the '*' but it doesn't work, the I replaced it by '*.*.*.*' and it works because in the structure of my DPs I have alerts at the 4th level !!
