Table. Catch columnWidth in runtime.
11 posts • Page 1 of 2
m.sabitov
Post by m.sabitov »
Hi!
How i can catch columnWidth in runtime?
Re: Table. Catch columnWidth in runtime.
columnWidth or namedColumnWidth
m.sabitov
Post by m.sabitov »
Sorry, its was bad question.
How i can catch columnWith, when i am changed column with using mouse
You can't. What is the use case ?
m.sabitov
Post by m.sabitov »
I need create buttons for opening filtering menu (like as in MS EXCEL filter). I can create button over table header in right position, but i cant change button positions if i'm changing column width
You can try to use a Button or ComboBox widget inside a cell. See cellWidgetRC
m.sabitov
Post by m.sabitov »
Maybe, but its dont work in header/
if you want to create an own "header" you could set the header invisible.
The own header is then defined with objects above the table.
m.sabitov
Post by m.sabitov »
Hello
But if change column with, objects above must change positions relatively new column widht. I cant do this.
as Martin Koller has written you can add a widget to a cell.
If you add widgets in the first line you can remove the header and use the first line as header.
Then you do not have to resize the widgets on your own as they are part of the table.
