Creating an API Manager
9 posts • Page 1 of 1
mhargreaves
Post by mhargreaves »
I am trying to create an API Manager but the checkAPIEnv.cmd fails with an error message
** cannot determine 'cl' compiler version! Maybe no compiler or wrong compiler version installed. VC12 expected.
I am running VS2012 (VC11). Does this mean I have to upgrade to VS2013 (VC12) or can I make it work with VS2012?
Re: Creating an API Manager
when using WinCC OA 3.13 you have to install Visual C++ / Visual Studio 2013 (VC12) Compiler Version 18.00.30501 for x64.
mhargreaves
I have now used VS 2013 but even though I have followed the instructions as best as I can, I still get an error
Error 1 error LNK1112: module machine type 'x64' conflicts with target machine type 'X86' C:\\Siemens\\Automation\\WinCC_OA\\3.13\\api\\Rcm\\libManager.lib(libManagerV313.dll) RcmManager
mhargreaves
I realised what is wrong - was using the normal Command Prompt instead of the "x64 Cross Tools Command Prompt"
mhargreaves
I have now managed to build my application ('demo') but when I try and debug it in Visual Studio 2013, it closes at the first demoResources::ini 'begin' function
begin(argc, argv);
while ( readSection() || generalSection() )
end(argc, argv);
Any suggestions on why it is failing?
I am putting arguments as '-num 6' - is this correct?
Where should I put the config file if running directly from Visual Studio?
A little bit too little information here.
Try running with -log +stderr and don't forget to pass it -proj yourProjectName so that it finds the config file.
mhargreaves
I have tried to install VS2013 on a Siemens 'CAT Client' machine but the installation always fails. Has anyone else from Siemens also experienced this?
our developers are using VS2013 on CAT clients.
The installation therefore should work.
Please get in contact with your system administration.
fmulder
Post by fmulder »
Make sure to start your api manager with (atleast)
"-num 6 -proj MYPROJECT"
Good luck
