I have the next problem case:
* Need to read values from Oracle database and write them into datapoints
* I use dbOpenConnection() and dbExecuteCommand() commands
* The problem is that after 30 seconds of execution occurs error with messages
WCCOAui7:["Errornumber : -2147217871"]
WCCOAui7:["BaseError : 1013"]
WCCOAui7:["Description : [Oracle][ODBC][Ora]ORA-01013: user requested cancel of current operation
WCCOAui7:"]
WCCOAui7:["SQL-errortext: S1T00"]
The question is - how to increase timeout for command execution for dbExecuteCommand() function?
If try to run SQL command in IDE (dbForge, for example) - the command will executed successfully for 1 min and 30 sec.
Code of test panel is below:
#uses "ctrlADO"
string connectionString = "DSN=AIISKUE;UID=S1;PWD=S1;";
main()
dbConnection connection;
if(OpenDbConnection(connection))
string sqlQueryString2 = "SELECT bvi.N_FID, bvi.N_GR_TY, bvi.N_INTER_RAS, bvi.VAL FROM CNT.BUF_V_INT bvi WHERE bvi.N_FID = 101 AND bvi.DD_MM_YYYY = TO_DATE('09.11.2015', 'dd.mm.yyyy')";
dbCommand dbCmd;
dbRecordset rs;
int res = 0;
dbStartCommand(connection, sqlQueryString2, dbCmd);
if(res != 0)
DebugLastError(connection);
else
DebugTN("START EXEC");
res = dbExecuteCommand(dbCmd, rs);
if(res != 0)
DebugTN("EXEC ERROR");
else
while(!res && !dbEOF(rs))
res = dbMoveNext(rs);
DebugTN("DONE");
if(res)
dbCloseRecordset(rs);
CloseDbConnection(connection);
private void DebugLastError(dbConnection connection)
int errCnt, errNo, errNative;
string errDescr, errSql;
dbGetError (connection, errCnt, errNo, errNative, errDescr, errSql);
DebugN("Errornumber : " + errNo);
DebugN("BaseError : " + errNative);
DebugN("Description : " + errDescr);
DebugN("SQL-errortext: " + errSql);
private bool OpenDbConnection(dbConnection& connection)
int resOpenConnection = dbOpenConnection(connectionString, connection);
if(resOpenConnection != 0)
return false;
return true;
private bool CloseDbConnection(dbConnection& connection)
int resCloseConnection = dbCloseConnection(connection);
if(resCloseConnection != 0)
return false;
return true;
