Extend Gedi
Extend Gedi
I want add Functions to Gedi Menu (right click)
I can see show but if i click it nothing happens
(scripts\\gedi\\test_ext.ctl)
My code:
#uses "CtrlPv2Admin"
main()
  pvConnect("openExplorer",   "show");
openExplorer(string filename)
  DebugN(filename);
  system("start cmd /c calc.exe");
>>> Here a Screencapture https://youtu.be/GUfjmnY7utU
Re: Extend Gedi
pvConnect() can ONLY be used from inside scripts/gedi/projectView.ctl
(the _ext.ctl scripts are used to add actions to the gedi menu/toolbars)
Re: Extend Gedi
The 'pvConnect' can also be used in the configured version control script.
By adding these lines to your config file you can make your gedi project view extension working:
[ui_extend]
versionControl = "test_ext"
Re: Extend Gedi
[ui_extend]
works perfect thx
Re: Extend Gedi
Here a demo Video what i made:
https://youtu.be/G203-Vwj7BY
