I have to change a variable at runtime in panel A and transfer it to panel B. The problem is that those panels are drag and dropped in the same panel C!!
I try to use addGlobal() and getGlobal(), using an internal DataPoint and use a dollar parameter variable and refresh the same panel using RootPanelOn() to support the translation of the variablile but i'm not able to run a script properly!
Note that in my specific case the variable in question is a type that contain a DP name.
Is there someone that have a solution?
Thanks in advance
Leonardo
change a variable between different panels at runtime
- Ladrone
Re: change a variable between different panels at runtime at runtime
if a variable is created with addGlobal() you can read/write this variable from every script in the same manager.
There is no need to use a datapoint element or a $-parameter to store a value in this variable.
- Ladrone
thanks for the reply!
I try those solution Leopold but I find that read a data in multiple inizialize scripts doesn't work. I solve putting alla scripts in the panel inizialize script.
Leonardo
Leonardo
