RDB manager does not start if a SCADA project is started from init.d using winccoa script in linux suse with user change from "root" to "MyUser" (with following command)
"sudo -u MyUser -E WCCILpmon &".
If same SCADA project is started from "WinCCOA console" (GUI app which is loaded as MyUser) RDB manager works fine.
In first case process WCCILdatabg is not started.
It seems that in bad case RDB manager cannot run Oracle client.
We have only to users defined: root and MyUser.
Oracle client is installed as MyUser.
Please find attached logs.
Please help me solve this issue.
Vedad https://www.winccoa.com/fileadmin/image ... ot_run.zip https://www.winccoa.com/fileadmin/image ... B_runs.zip
- vedadramovic
- Attachments
- RDB_runs.zip
- (7.06 KiB) Downloaded 202 times
- RDB_does_not_run.zip
- (10.54 KiB) Downloaded 208 times
Re: RDB manager does not start
is this problem related to another thread for your account?
https://portal.etm.at/index.php?option= ... 16&id=2818
- vedadramovic
Hi Leopold,
Yes this is the same problem as in other thread.
I am sorry for opening new thread with same problem.
ETM people is answering very fast, and in this case it I thought that no one was looking at it. So I reopened it.
Please erase it.
Vedad
Please erase it.
Vedad
