No datapoint connection to DNP3-driver
BOerther
Post by BOerther »
we created a new project and added DNP3-driver to console with index 2.
Then some panels from another project have been copied manually to the new project.
This panels are able to create a new DNP3-device within a script.
Also some datapoints are created automatically with a script. B)
In another panel for reading and writing these datapoints we see that the datapoints have no connection to DNP3-driver.
So if we open para and navigate to every DNP3-datapoint we have to click the button "assume".
Before that action the Manager was UI -num 0, after that: driver -num 2.
Then the single datapoint connects to the driver and values will be transferred.
This must be repeated for every datapoint. :(
How can we avoid this actions to every datapoint?
Best regards
Re: No datapoint connection to DNP3-driver
if you are configuring addresses for a driver number which is not 1 you have to configure first the _distrib config and set the required driver number. Afterwards the settings for the _address config are made.
Maybe this step is missing in your procedure.
