Hi there,
I have troubles on timesync WinCC OA -> S7-1500 PLCs (WinCC OA 3.13 P8).
None of the two possibilities I know work:
* Setting DPE :_.Time.SyncTime
* Using config entry AutoTimeSyncFactor
I also noticed that the DPE :_.Time.Value isn't updated using config entry ReadPLCTime = "Y"
I couldn't find any topic nor further informations in online help, anybody has experience with S7-1500 timesync? Are any further settings to do in S7 to use wincc oa's default timesync?
br petr
EDIT: I forgot, I get the same error message (permanent, on each alive-request) like Christoph Fankhause ([url]Topic: Problems connecting to S7-1500[/url]):
WCCOAs7 (1), 2015.10.20 19:27:09.154, SYS, SEVERE, 13/s7, Allgemeiner AGLink-Fehler (0xfff50005) für PLC_PS1_BMB2_00(8/1), 14, 33028
WCCOAs7 (1), 2015.10.20 19:27:19.140, SYS, SEVERE, 13/s7, Allgemeiner AGLink-Fehler (0xfff50005) für PLC_PS1_BMB2_00(8/1), 5, 33028
WCCOAs7 (1), 2015.10.20 19:27:24.141, SYS, INFO, 59/s7, SPS 'PLC_PS1_BMB2_00' in Zustand RUN (device 8).
WCCOAs7 (1), 2015.10.20 19:27:29.143, SYS, SEVERE, 13/s7, Allgemeiner AGLink-Fehler (0xfff50005) für PLC_PS1_BMB2_00(8/1), 5, 33028
Setting the config entries written in the thread has no effect
Can\'t sync PLC time (S7-1500)
Re: Can\'t sync PLC time (S7-1500)
I do not think all features of the S7-1500 are supported yet.
At the moment you could synchronize thru a ntp server.
