I have a "dpQuery" function, connected to a DP with a type "_dpGroup", named _DpGroup00017_Public
When a DPE listed in the _DpGroup00017_Public.dps, has its value changing, the callback is called as expected.
But, when I add a new DPE in _DpGroup00017_Public.dps list (with "setGroupFilter" function), after the dpConnect.
When the new DPE's value is changing, the callback is not called.
Is it possible to update the list and keep the callback active?
regards
Emmanuel
Update DP type _dpGroup
Re: Update DP type _dpGroup
I made a test with a dpQueryConnect and a filter for a dp group.
If the configuration of the dp group is changed a hotlink is received with those dp-elements which have been added to the dp group.
Therefore it is possible to change the dp group during runtime of a query connect.
I couldn't find a function called setGroupFilter() in WinCC OA.
Have you defined this function on your own?
- eMichx
setGroupFilter function is defined in the dpGroups.ctl library (included in WinCC OA 3.12)
regards
Emmanuel
regards
Emmanuel
