Wincc OA 3.10 SP2 - Datapoint does not exist after install patch P037
pmdiniz
Post by pmdiniz »
Please, does anyone know if after installing patch p036 in WinCC OA 3.10 SP2, it is a normal behavior have few warning about Datapoint missing for S7 driver when project starting up ?
PVSS00data (0), 2015.08.08 17:27:13.360, SYS, INFO, 0, , Manager (SYS: 1 Driver -num 4 CONN: 1) initialised
PVSS00s7 (4), 2015.08.08 17:27:13.362, SYS, INFO, 6, Initialization by Data Manager finished
PVSS00s7 (4), 2015.08.08 17:27:13.370, SYS, INFO, 3, Trying to connect to, (SYS: 1 Event -num 0 CONN: 1) @ SERVER1-1:4998,SERVER1-2:4998
PVSS00s7 (4), 2015.08.08 17:27:13.403, SYS, INFO, 4, Connected to, (SYS: 1 Event -num 0 CONN: 1) @ SERVER1 (127.0.0.1)
PVSS00event (0), 2015.08.08 17:27:13.412, SYS, INFO, 4, Connected to, (SYS: 1 Driver -num 4 CONN: 1) @ SERVER1 (::ffff:127.0.0.1)
PVSS00s7 (4), 2015.08.08 17:27:13.432, SYS, INFO, 156, Driver initialization finished.
PVSS00event (0), 2015.08.08 17:27:13.445, PARAM,WARNING, 7, Datapoint does not exist, DP: :_original.._value, MAN: (SYS: 1 Driver -num 4 CONN: 1)
PVSS00event (0), 2015.08.08 17:27:13.446, PARAM,WARNING, 7, Datapoint does not exist, DP: :_original.._value, MAN: (SYS: 1 Driver -num 4 CONN: 1)
PVSS00event (0), 2015.08.08 17:27:13.447, PARAM,WARNING, 7, Datapoint does not exist, DP: :_original.._value, MAN: (SYS: 1 Driver -num 4 CONN: 1)
PVSS00event (0), 2015.08.08 17:27:13.448, PARAM,WARNING, 7, Datapoint does not exist, DP: :_original.._value, MAN: (SYS: 1 Driver -num 4 CONN: 1)
PVSS00s7 (4), 2015.08.08 17:27:13.461, PARAM,WARNING, 54, Unexpected state, Cannot get DPID for _Driver4.AL.AClasses:_original.._value
PVSS00s7 (4), 2015.08.08 17:27:13.463, PARAM,WARNING, 54, Unexpected state, Cannot get DPID for _Driver4.AL.AckDps:_original.._value
PVSS00s7 (4), 2015.08.08 17:27:13.464, PARAM,WARNING, 54, Unexpected state, Cannot get DPID for _Driver4.AL.AckData:_original.._value
PVSS00s7 (4), 2015.08.08 17:27:13.465, PARAM,WARNING, 90, DP attribute was connected twice, DP: (Type: 0 Sys: 0 Dp: 0 El: 0 : _original..)
PVSS00s7 (4), 2015.08.08 17:27:13.466, PARAM,WARNING, 54, Unexpected state, AlertDrvIntDp, dpReady, dpConnect failed to Ack DPs
PVSS00pmon (1), 2015.08.08 17:27:13.507, SYS, INFO, 1, Manager Start, C:\\Siemens\\Automation\\WinCC_OA\\3.10\\bin\\PVSS00s7.exe -PROJ CJ70_BOP -pmonIndex 17 -num 5
PVSS00s7 (5), 2015.08.08 17:27:14.129, SYS, INFO, 1, Manager Start, PROJ, CJ70_BOP, V 3.10 - 3.10 P017 linked at Jan 25 2013 13:49:01
Re: Wincc OA 3.10 SP2 - Datapoint does not exist after install patch P037
This problem is not related to the installation of patch P036 or 037.
An explanation for the log-messages written by the event manager can be found in the ETM Portal --> FAQ --> Log-Messages:
The log-message written by the driver should also not occur anymore if the necessary _DriverCommon-datapoints are existing.
