I have to start without the login panel and start with the mainModule_1 and Pantalla_Inicial.pnl in the middle.
So the first view when the computer switchs on is the attached file.
In the console I have configured the line above:
C:\\Siemens\\Automation\\WinCC_OA\\3.13\\bin\\WCCOAui.exe -proj ETAP_IZORIA -m vision -p vision\\login.pnl -iconBar –menuBar
But the end customer wants the image I have attach, and I can`t find how to configure that line with one module in the online help. ¿Can you help me?
I have put the image, but appears without the main module.
Thanks for your attention,
Menoyo Larrea, Arkaitz
Start with mainmodule instead login panel
Re: Start with mainmodule instead login panel
I do not see an attached image. Could you post an image of your current result?
