Hi all,
it seems that the -localLicense parameter does not work with 3.13 as it does with previous versions.
In fact I can start gedi from my engineering pc connecting to a project that has no para license, so the initial license request works fine; cause otherwise gedi wouldn't start at all. But when the server does its cyclic license request, the remote's ui parameter -localLicense seems to be ignored, so that event manager closes the ui's connection and I have to restart gedi each 1/4h when working on a site's project that has no para license.
First I thought there could be any security issues like VPN, routing or firewall settings, but even in LAN I got kicked after the server's license request.
Can anybody confirm this behavior?
Thanks in advance for you help.
Troubles with -localLicense
Re: Troubles with -localLicense
we already know about this problem and our development department has started to analyze it.
Right now we cannot tell you when the problem will be fixed. Please have a look at the upcoming patches. If the problem is fixed you will find the information in the readme files.
