Good day
I faced some problem with WinCC OA project
When using Project Administrator I select any project (Getting Started, DEMO, My project ... ) I see the error popup window:
"Missing or erroneous progs or config file! For further information see the log file: WINCCOA_PATH/log/WCCILpmon_SERVERNAME.log"
This log file is empty at all.
This error blocks project starting (I can't select "Start project" button). The only thing that can help me is reinstall WinCC OA (v3.12). But it helps only for the next project restart.
I don't know what to do and I need your advice
Re: Missing or erroneous progs or config file
What version, what OS ?
Check the logfiles in the PROJECT (not in the installation path).
Check your file access rights. Can you read the progs/config file with some text editor ?
Can you create new files inside the projects log directory ?
- Piterskiy
Thx for help, Martin!
It was really bad days but I found the solution
To Run Project Administrator with Administration rights
