Create panel and buttons from script
gmcphers
Post by gmcphers »
So I am creating a library and I want to create some wizards to help people construct items more quickly. I am hand crafting the wizards for some specific specs so I am not using the wizard builder. I would like to be able to be able to create panels and push buttons in the the actual code. So are there any functions or anything like that where I can make a new push button on a panel or make a new panel from code? I have searched the help but I haven't seen anything. Thanks for your time :)
Re: Create panel and buttons from script
with the CTRL-function createPanel() you can create a new panel.
Inserting graphical objects via script functions to save them in the panel file is not possible in a simple way.
You could create the panel in Gedi, save it as xml-file and have a look at the panel file in xml-format.
Then you can write your own functions which will create xml-files.
Why aren't you using the Gedi to create the panels?
Another possibility is to load reference objects (panel files) during runtime using the CTRL-function addSymbol(). With this function you can put new references to a panel in runtime. This information is not saved in the panel file then.
gmcphers
Post by gmcphers »
So I am taking a text document with about 2000 panels names on it and I am going to make code that creates each panel with the corrosponding name as well as the panel topology. I was going to make a wizard that would also create some of the button structures on the panels. Thanks very much for your help and time :)
