Run WinCCOA as service under Linux
7 posts • Page 1 of 1
Heinrich
Post by Heinrich »
we have a WinCC OA 3.12 under LINUX Cent OS.
We have problems to run the server as service with a user login ("winccoa").
The server-project runs fine if I start the project with the console (both, as user and root).
Furthermore, the project starts as service with root privileges. But:
if I change the /etc/init.d/winccoa file to
$Echo "Starting WinCC OA: "$PVSS_II"\\c"
sudo -u winccoa WCCILpmon &
starts the pmon as user "winccoa" but not the project.
What can be wrong, some ideas?
I Hope that you can help with this problem
Best regards
Uwe Heinrich
Department ELBAS, Section Studies and Development
SIGNON Germany GmbH, Dresden
Re: Run WinCCOA as service under Linux
I'm doing it like this:
sudo -u winccoa -E WCCILpmon &
-E ... Indicates to the security policy that the user wishes to preserve their existing environment variables.
As you don't use -E, this might be the problem since the init script sets some env vars needed
Heinrich
Post by Heinrich »
Hi Martin,
thank you very much. It works great.
I replaced the lines to (your hint "-E" and the full path):
sudo -u winccoa -E ${PVSS_PATH}/bin/WCCILpmon &
That would be something for the help ... ;-)
Best regards
Uwe Heinrich
Heinrich
Post by Heinrich »
another problem again ...
WinCC OA runs now under Linux as service, but now I can't run the gedi and other ui. Following error message:
WCCILpmon1:No protocol specified
WCCILpmon1: WCCOAui: cannot connect to X server 127.0.0.1:1.0
WCCILpmon1 ... 24/pmon, Erhielt START Befehl von ::1, starte dem Manager WCCOAui(1) auf Index 28
I knew this errormessage in the past, but I fixed it with the command "xhost +". Thats never work now.
Maybe I can create an extra WinCCOA-project only for the gedi and uis at the same server for running uis, but ...
any other ideas ?
Thanks an best regards
Uwe Heinrich
Yes, that's expected. Pmon is run from init, which knows nothing about the later started X Server.
In fact, you should not run a UI via pmon when pmon runs as service, since all manager are in the background and the UI is user specific inside the X Session.
Quick-hack solution: pass the commandline argument "-display :0" to the UI in console after you used "xhost +" to allow acces to your X Server.
Better solution: run the UI from your desktop without using pmon, e.g. create a UI.desktop file for it, e.g.:
[Desktop Entry]
Icon=/opt/WinCC_OA/3.13/pictures/vision_32x32.png
Name=WinCC_OA UI
Exec=/opt/WinCC_OA/3.13/bin/WCCOAui -proj test3x
Type=Application
Heinrich
Post by Heinrich »
Hi Martin, Thank you for fast answer and help.
both works well
many Thanks
Uwe Heinrich
Heinrich
Post by Heinrich »
Another way:
After problems with the env-vars at booting we use su instead sudo
USER=winccoa
su $USER -c "${PVSS_PATH}/bin/WCCILpmon &"
Best regards
Uwe Heinrich
