GEDI UI reproducible bug (\"UI has crashed unexpectedly\")
TBURKE2
Post by TBURKE2 »
Hey guys! I'd just like to share a bug I encountered with the GEDI user interface that causes the manager to crash. Thus far, on my installed copy of WinCC OA 3.13, the bug is 100% reproducible.
If you are working on a panel, and you want to cut any object, delete it, save the panel, and then close the panel, in that particular order without clicking or doing anything in between operations, the interface is guaranteed to crash. I did each operation using keyboard shortcuts, not by right clicking.
So again, with shortcuts; select an object, cut (CTRL + X), delete (Del), save (CTRL + S) and then click on the close button for the panel.
Let me know if this is a confirmed bug, or just my installation. Thanks!
Andorhal
Re: GEDI UI reproducible bug (\"UI has crashed unexpectedly\")
Post by Andorhal »
Hello.
Reproducable here as well.
Interesting behaviour.
The additional delete seems to be the problem, since Ctrl+X already removes the object from the panel and saving/closing without the delete works just fine and results in a saved panel without the object.
We´ll track that error.
Thx for reporting it.
riccardo.crociani
Post by riccardo.crociani »
I'm using WinCC OA 3.11 and I don't get the same bug...
Riccardo
agruber
Post by agruber »
Thanks for letting us know. We could reproduce that issue with 3.13 P003 and P004.
I am happy to tell that with the upcoming patch P005 for 3.13 this issue seems to be solved.
BR,
Andreas Gruber
Head of WinCC OA Customer Care
