Quick question - I'm doing a lot of work editing small bits and pieces of library files, but in order to have the changes I make go into affect, I have to restart all the managers. Is there a single manager I can switch off and on to prevent closing and reopening the whole project, or a way to simply refresh the libraries so they take effect immediately?
Thanks.
Refreshing library edits without restarting managers?
- TBURKE2
Re: Refreshing library edits without restarting managers?
When a library is used by multiple managers, they all have to load the library. The loaded library is not shared thru an interprocess communication.
So you would only need to restart the manager, which uses the library. I never restart the whole project for a library change. In the Gedi you could use the 'Reload CTRL Libs' option from the 'Edit' menu, if it is not already automatically reloaded.
reloading the library in the UI by the option to reload the libraries in Gedi is only possible if the library is not in use.
You have to close the Vision modules where panels are loaded which are using the library you have modified.
In rare cases this does not work, then you have to restart the manager. E.g. I had this problem when modifying the aes.ctl library.
- TBURKE2
That was the manager I was changing as well, which explains why I had to fully restart the manager to get changes to take effect.
Oh well, I guess I'll keep doing what I'm doing.
Thanks!
Thanks!
Hint: on Linux, you can send a CTRL Manager the signal SIGUSR1 (from a shell) to let it reload all scripts and libs
(it will stop all scripts, reload all, restart scripts)
