It seems the component WebView.ewo (for 3.12 P18) is not HTML5 compatible . Is there anyway to
have an HTML5 compatibility on this component (WebGL and Hardware optimization)?
If there's no other possibility, do you advise to use an ActiveX or something else?
regards
Emmanuel
WebView.ewo (HTML5 compatibility)
- fmulder
Re: WebView.ewo (HTML5 compatibility)
I can't answer your question about HTML5. What I can say:
- ActiveX require registration
- ActiveX don't always integrate very good (I've seen several ActiveX's crash)
So, when you know Qt and you want the best integration, then I'd advise you look at Qt. It does take some time to lear Qt but Qt is superior over the libraris that you'll get from Microsoft
good luck
Frenk
good luck
Frenk
Another topic mentions that the Qt version of version 3.12 is probably too old for having HTML5 support.
You should try it with 3.13 or enable plugins with the code:
WebView.setAttribute("PluginsEnabled", true);
