upload an IMG or FILE to the Message?
An off-topic general discussion forum to chat about ANYTHING!
8 posts • Page 1 of 1
Heinrich
Post by Heinrich »
it is possible to insert or upload an IMG Image or FILE to the Message?
The "Preview" shows nothing :-(
Thank you
Best regards
Uwe Heinrich
Heinrich
Re: upload an IMG or FILE to the Message?
Post by Heinrich »
If I edit the post, shows the Editor:
[img]https://www.winccoa.com/fileadmin/images/fbfiles/images/question.gif[/img]
In my opinion a correct code.
Anything wrong with the upload?
How do I upload a image or file?
Uwe Heinrich
Andorhal
Post by Andorhal »
There seems to be a problem with the image upload folder.
You could attach the graphic as file, that works.
Or you could even do this workaround:
Upload the image as file, copy the file path, edit your post and put e.g.
 [img]https://www.winccoa.com/fileadmin/images/fbfiles/files/diagnosis-20150527.png[/img]
inside it, so it shows the image right in the post as shown below
Heinrich
Post by Heinrich »
only for testing the workaround:
1. create:
2. edit:
3. :-)
Thanks a lot
Andorhal
Post by Andorhal »
The problem with the image folder has been fixed.
Images can be used again i the proper way with the image attachement.
ack_all_alarms.zip
(1.89 KiB) Downloaded 287 times
Heinrich
Post by Heinrich »
Hi Robert,
thanks for fixing that.
Another point:
zip-files (and ... ?) can't be uploaded as "".
Regards
Uwe https://www.winccoa.com/fileadmin/image ... 150602.zip
ack_all_alarms_20150602.zip
(1.89 KiB) Downloaded 286 times
Andorhal
Post by Andorhal »
Hello Uwe.
.zip Files are allowed.
You can see all allowed file types within the yellow Hint Line when you click the "Select file" Button.
See attached. https://www.winccoa.com/fileadmin/image ... 150602.zip
ack_all_alarms-20150602-2.zip
(1.89 KiB) Downloaded 280 times
ack_all_alarms-20150602.zip
(1.89 KiB) Downloaded 283 times
Heinrich
Post by Heinrich »
Hallo Robert,
[strike]maybe only a problem from extern (firewall or virusscan ... ?). [/strike]Edit: No!
If I upload Your File again, it´s working (with the same link).
With another file or Your file renamed to test.ZIP - nothing :-(
best regards
Uwe Heinrich https://www.winccoa.com/fileadmin/image ... s/test.zip
PS:
Now its working! :-)
The problem is the fileextention!
*.zip is good and *.ZIP is bad
test.zip
(1.89 KiB) Downloaded 292 times
