Master Data Point - Default Value
MrKintaro
Post by MrKintaro »
Maybe is a stupid question but I need an urgent solution.
I created a Master DP from a DP that I created.
Afterword I wanted to create a multiple element of the DPT.
I decided to use Excel Plugin.
I imported the DP and the strange thing is that the feature to set a Defaul_Value for a single element is missing.
Am I wrong? I tried different time and exportation but is not working.
I need this features becasue for example the name of the picture to show is set in DPE and do I need to write this string manually?
Thanks in advance.
Re: Master Data Point - Default Value
from your description I could not see what you really want to do.
Do you want to set an original value when importing the ASCII-file or do you want to configure the _default-config?
MrKintaro
Post by MrKintaro »
My problem is when I create the master data point and I use the Excel Plugin.
There is no possibility to set the Original Value of the DP that I want to create with the Excel.
Thanks.
original values are normally not copied to the instances.
If you want to copy a configuration from the master datapoint to the instances it must be a part of powerconfig configuration. For the _original config right now a powerconfig is not available.
To copy the original values you can write an own script using the CTRL-function dpCopyOriginal().
Another possibility would be to create an own powerconfig which reads/writes the original value. If you define a variable which can be changed by the user you'll see this parameter in the ASCII-files using format V3/V4.
For detailed information concering powerconfigs please have a look at the WinCC OA online help in chapter "Mass configuration".
