What am I doing wrong??
- aorange
Ok, so I am quite rusty as I haven't used WinCC-OA in 2 years but something doesn't add up here. Can anyone explain what I am doing wrong or missing?
Re: What am I doing wrong??
with the function dpNames() you will get a list of dp-elements which match the pattern.
There is no check made if the config you have added at the pattern is really exisiting. Therefore the result is okay.
- aorange
But if the config doesn't exist the surely it couldn't possibly match the pattern, right?
- aorange
hmm think I got it.. it just doesn't take the config part of the pattern into consideration.
Is there a way to test if a config exists then? I seem to remember having done this but as I said, I am very rusty
The config exists when:
:.._type != DPCONFIG_NONE- fmulder
Jonathan,
You can do a dpGet() on the ".._type". When the value is not 0 then the config exists.
