I am making OMRON(CS1G_CPU44, FINS protocol) driver-manager, with the tool and environment you supplied.
My WINCC OA Version is 3.12, and I am doing this job with VC2010, 64-bit environment.
And I am doing this programming, using the project \\\\WinCC_OA\\3.12\\api\\TcpDrv\\TcpDrv.vcxproj, which is kindly included in your package.
Last week, I succeeded in communicating with the OMRON Ethernet card.
Every scan time, I can read 800-words from OMRON and inserted them to my data-structure (more specifically, STL-MAP data-structure).
But This week, I am struggling to solve the problem.
The problem is, I cannot know how to transfer My OMRON-DATA to PVSS-DP(data-point) variables.
One of my try is using the class, HWMapper, and below box has the part of my code.
--- My code ---
HWMapper *pMapper = (HWMapper *)DrvManager::getHWMapperPtr();
for( HWObject *pHWObject = (HWObject *)pMapper->getFirstHWObj(); pHWObject != NULL; pHWObject = pMapper->getNextHWObj() )
std::cerr
Problem in developing Channel Driver for Omron PLC
- heony
Re: Problem in developing Channel Driver for Omron PLC
I'm not an API-specialist.
For transferring data to the original value you need a dp-element with an _address-config defined as input address.
As far as I've seen from the C++ code for the common driver the functions processData2Dp and sendData2Dp are called to write data to the original value.
The 'Transformation' class is responsable for transforming external data to pvss variables. More information regarding this class can be found in the api docu/header files and the online help under: Special functions -> API -> ComDrv driver -> Transformation.
The data can be send to pvss by the 'DrvManager::toDp' function.
