• Page 1 of 1
fandersen
Variable type not suitable for archiving
Postby fandersen »
in my log viwer I get a servere message that the variable type is not suitable for archiving. How can I diagnose the problem properly?
I know how to spot the affacted data points but not the element. Is there a way to get the elementName by elementId?
12.09 10:22:47.459,
IMPL,
SEVERE,
54,
Unexpected state, Variable type not suitable for archiving (ErrNum=14),
ErrorDP: DpId = 444, elementId = 47,
According the information in watch object, stored element has vartype 40000, but incoming value is of vartype 70000,
[D:\\workspaces\\3.12\\workspace\\Exe\\DataNew\\ValueArchive\\Archive.cpp:2648]
You can get the dpe name by id in CTRL with the function 'dpGetName()' or with the tool 'WCCOAtoolNameToId' (in online help under Reference tables -> DP identification).
in most of the cases you can get rid of this error with the following list of actions:
-- open a para-module
-- select the dp-element for the given DPE-ID
-- open the configuration panel for the _archive-config
-- select another archive
-- save the configuration
-- make a fileswitch for the archive which has written the log-message
-- open again the configuration panel for the _archive-config
-- select the archive which was used before
A loss of data will not occur when doing these changes.
