How can I fill whole screen when I use panel topology
yjsid939
Post by yjsid939 »
hello...
As mentioned I want to fill all my screen.
First of all, I use -menuBar option because My client don't want to see windows border and titlebar.
But if I use these options, I can't fill the screen.
For example, Monitor resolution is 1920x1080 and my templete' resolution for panel topolgy is 1920x1080 also.
But when I execute the project, project windows size is about 1920x1050...
And one more question about User change.
Because I want fill the screen, I tried to start without paneltopology but in this case if I used login panel, project restarted with panel topology.
How can I change login user only not restart project with login panel?
Plz, let me know How.
Re: How can I fill whole screen when I use panel topology
the predefined templates are designed for specific screen resolutions including the titleBar.
If you want to use the complete screen whitout a visible titleBar you have to modify the size of the panels at the graphical editor.
There is no option to switch them to "fullscreen" automatically.
When you have configured a panel topology this setting will be used when the login-panel is used for the login.
The last question I didn't understand. Can you please describe in detail which function shall be realized.
fmulder
Post by fmulder »
I have often crated my own templates based on panel topology. In my template I always add the following code:
titleBar( false );
moduleOriginalSize();
Hope this helps. Good luck !
yjsid939
Post by yjsid939 »
Thank you Knipp and Mulder!!
after read your opnion, I set panel size and add 1 line "moduleOriginalsize" and It works!!
Last few weeks I tried to solve this issue.
Thank you again!!
Have a nice day!!!!
