Size of variables in bit (or bytes)
eMichx
Post by eMichx »
I'm looking for a function which will return the size of a any variable (anytpe, char, bool, dyn_xxx, blob)
in bits or in bytes.
I have found nothing in the help or in ctl scripts of WinCCOA.
best regards
Emmanuel
Re: Size of variables in bit (or bytes)
can you please describe what the usecase would be for such a function?
What is done with the result?
An anytype variable does not have a fixed size. How many bytes are needed depends on the value saved in the anytype variable. It is the same for the other variables.
eMichx
Post by eMichx »
Hi
I'm using blob to insert value, but trying to optimize the length.
For example, add 8 bits to create a bytes, to avoid using a byte
to encode a symple bit.
When you have an unsigned, sometimes it's interesting to
encode it to N bits (N
In the online help under CONTROL -> Introduction CONTROL -> Data types you can find the sizes of the fixed size variable types.
