as written in the \"dyn\"
Arbudu
Post by Arbudu »
Hi all, faced with the problem! How to write a value in dyn_float or dyn_int ???? produces an error.
fmulder
Re: as written in the \"dyn\"
Post by fmulder »
I'm not sure I understand your question.
If you want to write to a dyn_float you can simply do:
dyn_float df;
df[1] = 1.0;
df[2] = 2.1;
There are also functions to manipulate a dyn:
dynAppend( df, 2.0 );
Good luck
Frenk
Arbudu
Post by Arbudu »
I added the script to the text field to be able to record the values ??and make a binding text field to the DP. and when I began to write the value it generated an error
can not append to dyn Image
if a log-message occurs during an operation it is useful to see the complete log-message.
When you want to modify the dyn_string saved as value at a dp-element you have to
-- read the value with a dpGet()
-- modify the dyn-array with one of the functions mentioned in a previous posting
-- save the value with a dpSet()
