This is an information to the users of the I/O counter.
The I/O counter is an very useful panel to count datapoints which are relevant for license calculation.
We used it in our project. But the result was not correct, even it depended on the system load. The implementation of the panel realizes a delay operation which is set to 3 seconds hardcoded. This was too short for our project.
When you use this panel then change the delay-time and re-run the panel. Compare the results.
source code snippet:
for(d=1;d
I/O counter handle with care !
Re: I/O counter handle with care !
if you want to avoid a fixed delay you could use a while-loop (with a short delay of about 1-3 seconds) which checks if the datapoint-element has been updated.
Then you should always get the correct result.
