Hi!
I have a weird problem with my event list.
I have quite a few DP's that are configured for archiving into Oracle DB. All works fine and I can see them in my Event Screen.
I have just configure archiving on some of the internal DP's (for example "_ReduConfig.EvStatus"). It seems to work fine, I can see changes logged in my SQL report tool, but I can't see them in my Event List.
I've already spent two hours making sure mu filtering as all good and I still can't figure it out. Is that some known feature that Event Screen doesn't display internal DP's?
Event List and archived internal DP\'s
Re: Event List and archived internal DP\'s
if you want to see also internal datapoints and their elements at the Event Screen you have to modify the "Central settings" at the system management. The panel can be found in the tab "Settings".
Afterwards it might be necessary to restart the UI to take effect of the changes.
- n_lev
Thanks Leopold!
