List all references in a panel
adaneau
Post by adaneau »
Hello
I would like to get all the references in a panel through scripting.
For this I tried to use getshapes with attribute "panelFileName" which seems to be typical for a reference.
But unfortunately it returns me 0 shapes when trying to use "*" as pattern to get all the ref.
So I tried to do this:
getValue("myRef","panelFileName", test) where test is a string. So test returns me the correct value.
After this I also tested :
getShapes(myModuleName,myPanelName, "panelFileName" , test) where test is the previously gotten value.
Still returns 0 shape...
Has someone find a way to do this? Just want to have a list of all the references in a panel, whatever the way you use.
Thanks in advance
Regards
Alexandre
Re: List all references in a panel
I also could not find a CTRL-function which returns this information.
When you are not using dynamically added references (addSymbol) then you can parse the oanel file to get the references.
What is this information used?
