Problems with the licensing ios count
xavi.aran
Post by xavi.aran »
Hi! i have a project with 32580 ios. i need to make subproject from this 'father project'.
I copy the project and desactive all the adrees i don't need in the 'son project'.
I count the ios with the _DriverX.AD.HWMask & DPmatch method and tell me than i have 2865 ios.
I have the license for 5000 point, but the driver tell me than i have more ios than my license can give.
Why is the proble? I made anything wrong?
It's important because this week this subprojects will be works correctly.
Thanks!
Re: Problems with the licensing ios count
under special conditions the information at the internal datapoint may not reflect the real number of active addresses. This happens when you are configuring an address config at a structure element. At the dp-element you have only one entry, the real number of active addresses is the number of elements below this structure.
To get the correct number of active addresses you can use the following panel
https://portal.etm.at/index.php?option= ... &Itemid=79
